According to
www.vcdhelp.com "check DVD Hacks" it is the same as a DN-V300. Read all.
Region code hack posted by Bob, April 26 2005:
Region Free for an NTSC TV
1. Turn the unit on.
2. Press the OPEN/CLOSE button and open the tray.
(Keep the tray open during the setting.)
3. Press CLEAR 1 4 7 0 CLEAR - TEST MODE
will appear on the display.
4. Press the ▲cursor key and 00 XX (XX=this will be a
numerical value) will appear on the display. The first
two digits are incremented by one, every time you
press ▲
5. Press the ▲cursor key until you see 12 XX (default
is 24) on the display. Press 2 3 on the remote then
the ENTER button
6. Press the ▲ cursor key again and you will see 13 XX
(default is 23). If it does not say 23,
Press 2 3 on the remote and then the ENTER
button
7. Press the ▲ cursor key again and you will see 14 XX
default is 01). Press 0 0 on the remote and
then the ENTER button.
8. Press RETURN
9. Press CLEAR twice
10. Press RETURN (END should appear on the display)
11. Press the OPEN/CLOSE button to close the tray.
Region Free for a PAL TV
If you have a PAL TV follow all the steps but use 33 instead of 23 in steps 5 and 6
Region code posted by Bob, April 26 2005:
For the previous hack ▲" should be the "up" arrow on the cursor.
Region code hack posted by videoguru, April 26 2005:
This is the correct hack:
4. Press the upcursor key and 00 XX (XX=this will be a
press up
5. Press the upcursor key until you see 12 XX (default
the ENTER button
6. Press the up cursor key again and you will see 13 XX
button
7. Press the up cursor key again and you will see 14 XX
8. Press RETURN
