Is there a good 19" TFT with fast response times?
Discussion in 'PC Gaming & Rigs' started by blue_tarragon, Sep 10, 2003.
  1. blue_tarragon
    blue_tarragon
    Looking to go for a flat panel LCD screen. Play all sorts of PC games including a lot of FPS.
    Want a screen at 19" or more with a fast response time.
    Any ideas?
    Or is it best to go with a 17" Hitachi?
    I think I would find it hard to move down in size from a 20" CRT.
  2. Sinzer
    Sinzer
    May 25, 2002
    5,823
    +1,117
    17" TFT will be fairly close to a 20" CRT in size.
    Currently 19" TFT still use the older technologies and their response times are not great.
  3. uczmeg
    uczmeg
    May 18, 2003
    3,433
    71
    Nottingham
    +52
    I agree in physical screen size CRT screens are often a little exaggerated, TFT screens tend to be exact. So there is not much difference in viewable size.
    The difference will only be noticeable if you run high resolutions. If you run your old monitor at 1600x1200 (as I used to on my 21" at work) you are going to be hard pushed to get that from a 17" TFT.
    My 17" TFTs will only do 1280x1024 max, but the two together do a nice 2560 x 1024 ;)
    Marc
  4. blue_tarragon
    blue_tarragon
    Thanks guys.
    Sorry I wasn't that clear.
    My CRT is a 21" with a 19" viewable screen.
    Prob best keeping the CRT then or upgrading it to a larger viewable size perhaps on an Iiyama 22" or something similar.
    If the technology was better on the larger screens I would go for one, but all screens I can find over 17" tft seem to have response times at around 25ms which I know is not good enough.
    I use my CRT at 1280x1024 as a desktop and play games at either 1280x1024 or 1600x1200....
    Thanks for the advice
  5. BBCuk2day
    BBCuk2day
    May 10, 2003
    94
    LG are in the process of releasing a 19" tft wi 16ms response time which should clear ghosting up! I think the model number is 1910b or something close just look for the 17" version number thats quite popular at the moment and swap 17 for 19! Hope that makes sense quite tired bad day :)
    Got ya a link http://www.hardforum.com/showthread.php?threadid=664270
    Not a bad place for info!
    Also if you want to go for a 17" the one i am waiting to see is the samsung 172x which looks to be very good and is released sometime this month!
    But if you want one now the viewsonic seems to be very popular but has had problems as do everything these days :devil:
  6. Kramer
    Kramer
    19" with 16ms response - finally :clap:
    Still only 1280x1024 though :( Now 16x12, that'd would be nice :eek:
