Is there a fully working Sky+ Remote Code for the Pioneer 434HDE?
Discussion in 'Plasma TVs Forum' started by nujjy, Sep 28, 2004.
  1. nujjy
    nujjy
    May 26, 2004
    219
    +9
    Hi, all.
    I am struggling to get my Sky+ Remote to work with the Pioneer PDP-434HDE plasma television. I can control the volume and change channels on terrestrial. I can also fully work the Sky+ box. However, I cannot do anything else to the tv. I cannot change the input and as a result, the only way to access Sky is to switch on the TV and go up to to it and press INPUT on the side. Now, this is not laziness but I just don't want to go up to the Plasma each time I want to watch sky.
    I even phoned up Sky! They had no solution. They said that when you press the "Sky" button, it should automatically change to sky. It does this VERY rarely. They gave me some more codes and pressing "TV and Select" or "TV and Help" does not work.
    Please!!! I need to be able to change between Input 1,2,3,4 etc.!
    Can someone give me a working code or even tell whether this is possible?
    Thanks,
    Nujjy.
  2. Warpaint
    Warpaint
    Jul 26, 2003
    591
    28
    Edinburgh
    +61
    There is a setting in the pioneer menu which allows a channel number to be the AV1 input. This might give you a basic fix. If you are already using channels 1 - 5 then go to say channel 6, enter the home menu, go to the tuning menu and set the 'decoder' option to 'INPUT 1'.
    (See page 33 of the instruction manual.)
    This will mean that when you select channel 6 the TV will switch to AV1.
    hope this helps.
  3. mikeycrawford
    mikeycrawford
    Nov 27, 2002
    116
    It is possible, but doesn't deliver perfect results. You need to go to Programme Setup in the menu of the Plasma, select Manual Adjust then choose a spare Programme Entry (lets say 6). Tell this channel you have a Decoder on Input 1 (which should be where your sky is plugging in to the media receiver).
    You then follow the standard sky instructions for programming the SKY button (press TV, hold Select and Green until it flashes twice, choose the number that SKY is on - 6 in the above step - press select.
    Now whenever you press SKY button, it should take you to Channel 6 on the media receiver. The strange part is that the picture looks quite poor compared to Input 1, and sound is only in Mono. You might think that this is because it must be using the RF feed into the media box, but you will still get the same picture and sound, even if you have no RF lead going in.
    Not perfect, but a workaround.
    Mike
