IS there a Free hard disk partition manager
Discussion in 'Computer Software & Operating Systems' started by tvdavid, May 4, 2007.
  1. tvdavid
    tvdavid
    Feb 20, 2006
    2,605
    North Essex
    +120
    HI
    I have got a copy of vista but want to keep XP as my main OS.
    I would like to make another partition on my hard drive so I can boot into vista but dont know what to do.
    Are there any free partition managers on the internet?
    I tried google but there all ones you need to pay for.
  2. DancingJester
    DancingJester
    Jul 10, 2005
    137
    London
    +19
    I use gParted avaliable here.
    Unpack the image onto a cd and then boot from the cd. I just stick to the default settings for when it asked.
    There is a full guide to dual booting xp/vista here.
    Hope it helps :thumbsup:
    PHP:
  3. Paul_HDLover
    Paul_HDLover
    Jan 22, 2007
    1,474
    Nowhere
    +164
  4. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    Dual booting with Vista is fine but be aware MANY have had issues removing the XP partition when they decided to jump permanently to vista
  5. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    They have? Not that I've heard of. I'm currently dual booting with XP/Vista. Think I might try removing the XP partition, just to see if it gives me any trouble.
    Should be a straight forward process...
    1) Format the XP partition
    2) Re-install the Vista Bootloader - via the Vista DVD - repair option
    3) Merge the additional partition space with Vista Computer Management.
  6. willsy2
    willsy2
    Apr 22, 2005
    643
    28
    Newcastle
    +32
    Or use EasyBCD to do it.
  7. Uridium
    Uridium
    Jan 29, 2005
    14,434
    +1,855
    Number 2 is the sticking point for many
  8. willsy2
    willsy2
    Apr 22, 2005
    643
    28
    Newcastle
    +32
    I used the repair option to try and rectify some problems i was having and it trashed my system. I had to format and do a fresh install. :(
  9. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    Bit hard to use that when you can't boot into the OS in the first place lol.
    There is also VistaBootPro. Those tools are ment to be used when setting up a dual boot.
  10. tvdavid
    tvdavid
    Feb 20, 2006
    2,605
    North Essex
    +120
    I am using paragon partition now.
    Seems to have worked OK.
    I reinstalled XP but now can not get in to vista.
  11. Stiggy
    Stiggy
    Dec 7, 2004
    6,727
    Sandy Heath
    +1,043
    As Singh said above, try booting with the Vista DVD and select 'Repair' from options.
    In which order did you install XP and Vista, and what partitons are they in? Have a look in Computer Mangament/Disk Management if you're not sure.
  12. willsy2
    willsy2
    Apr 22, 2005
    643
    28
    Newcastle
    +32
    Nobody mentioned not being able to boot into it. I meant to use it as part of the process to remove XP.
