Is there a DVD player with manual audio sync control?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Skyav, Jul 21, 2004.
  1. Skyav
    Skyav
    Jul 20, 2004
    91
    Hello all,
    Does anybody know if there is such a thing as a DVD player that lets you manually offset the audio signal so that it matches with the picture? I've just started running DVDs through a projector, and I'm noticing the picture is lagging behind the sound a few frames.
    It seems to happen on some disks more than others, and I don't think it's my current DVD player (a Fusion model from Richer Sounds) because the lipsync was fine when running through a TV. I'm really fussy about sound sync but I can't afford any additional gear like one of those amps that lets you offset the audio.
    I can, however probably afford to upgrade my DVD player if there are any out there that have this facility.
    Any info would be much appreciated.
    Skyav :thumbsup:
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    AFAIK all the Arcam DVD players have a lipsync feature but they are not cheap players. I don't think you will get this feature on any DVD player at (much if anything) under £1000.
    Some disks are worse for lipsync than others, but the main problem is that the larger the display you are useing the more you will notice the lipsync issue.
    Mark.
  3. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    All Arcam DVD players except the original DV88 and DV27 have this feature (you may have to update the player SW on older DV88 Plus players).
    The DV78 retails for £699 and some end of line DV88Pluses/89s are available for rather less than this.
    HTH.
    John Dawson (Arcam)
  4. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    SBC (Swedish Born Chinese)/lived in UK since 96, C
    +32
    Skyav,
    With the prices of Arcam's even 2nd hand, you might as well buy a Yamaha 650 or 750 and still have £200-£300 left, and then you can adjust lip sync not only on dvds but also sky (also reported a lot of problems) if you would get one in the future.
    Wasabi
