Is there a correct way to fit a male and female plug?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Mr Kennedy, Mar 1, 2005.
  1. Mr Kennedy
    Mr Kennedy
    Feb 28, 2005
    921
    +22
    Hi i'm trying to get sky in my other room and i know now that the tv link is working so i've got it down to the male and female connectors. So is there a right way to fit these to the coaxil cable. I have the high sat cable, which has copper thin wires then a white plastic covering, and in the middle a single wire, i just stripped back the cable down to the wire and plugged that in, but this does'nt work.
    So is this the right way to connect these.
    thanks
  2. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
  3. Mr Kennedy
    Mr Kennedy
    Feb 28, 2005
    921
    +22
  4. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
