Is there a cable to connect a component out to the Pw6 VGA port without a JS tech
Discussion in 'Plasma TVs' started by calvinhobbes, Jan 30, 2005.
  1. calvinhobbes
    calvinhobbes
    Hi All
    I've got a new Pw6 and I wanted to know whether there was a high quality cable available to connect a component out YPrb from the SD44 to the Pw6 VGA port without having to buy a JS Tech box or a Component Board.
    If so, does it give the same quality?
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,648
    UK
    +112
    Yep, you just need a 3x RCA to HD15 cable.
    For a high quality one i would recommend 'bettercables' ones - Joe at 'The Media Factory' should be able to help as he is a uk dealer and i got mine there...not cheap, but excellent results
    JJ
  3. swarrans
    swarrans
    Dec 21, 2001
    404
    16
    Kent, UK
    See also the Van Damme cables at AV-Sales...
    Simon
