Is there a big difference between 4K HDR and 4K Ultra HD
Coldste
I’m looking at gettIng a new TV, every time I go to filter what I’m looking for I see two options one is 4K HDR and the other is 4K Ultra HD is there any major difference between these?
vickster
Info about HDR here
EndlessWaves
Sounds like wherever you're looking has poor filter options.
4K is also known as Ultra HD. It's a small resolution bump to fill in the remaining gaps that Full HD didn't cover. It's has very little effect itself for typical UK screen sizes and viewing distances. Although some content sources are choosing to offer higher quality versions of their programmes for the 4K versions, not just higher resolution, which does make a more noticeable difference.
HDR is a new set of picture standards with a much bigger impact, offering a wider colour and brightness range for content creators to use.
However, there's been no single big hardware jump, just incremental improvements at the high end becoming (slightly) cheaper over time. So the HDR standards are designed to be scaled down and use whatever hardware the TV does have.
And the marketing to communicate this has been terrible. Many TVs just state they can play HDR video and say nothing about how much of the new range they can reproduce - even budget and lower mid-range TVs with identical hardware to pre-HDR TVs.
So basically those categories are not generally meaningful and you should tick both options.
Coldste
Thanks for that really helpful, it was actually the Currys website that had the filters
vickster
Don’t buy from Currys :D
This guide gives you an idea of what TVs to look at, read the intro too
Neil69
4k UHD is the screen resolution of the TV. 3840×2160P. HDR is a different kettle of fish. HDR is high dynamic range. It's to do with more colours & to do with how bright & how dark it goes. HDR comes in lots of different flavours..Dolby Vision, HDR10+, HLG & regular HDR10. I hope that helps
Joe Fernand
AVForums Sponsor
As others point out 4K UHD refers to the resolution of the Display and features such as HDR add additional capabilities to the Display, those capabilities may or may not be enabled by or required by the Source content you are viewing.
Look at the capabilities of your Source device and content streams to form your ‘shopping list’ of Features you will want to support.
Joe
Not a sky fan
There’s is relatively little difference between uhd (4K same thing) and a good hd upscale picture on a decent tv. Esp on sky
so what I’m saying is, if going to the expense of buying a uhd4k tv, make damn sure it is hdr capable to avoid disappointment
hdr is a bigger step up in picture quality than the uhd standard is over hd.
So your not really buying a uhd tv your buying and hdr capable tv…. Or not at all it seems to me
Not a sky fan
Just to add, as mentioned above, the programme also needs to be hdr capable and not all are, but it appears to be on the way
… finally
