Is there 1 home phone that i can use on 2 lines ??
Discussion in 'Mobile Phones Forum' started by hot-fuzz, Dec 31, 2006.
  1. hot-fuzz
    hot-fuzz
    Dec 13, 2005
    6,086
    Hampshire/Surrey, UK
    +593
    Hello,
    I have at home the Orange Livebox which gives me cheap calls across the UK and free to Orange numbers etc etc, so i use my BT line to receive calls and use the livebox to make outgoing calls.
    At the moment i unplug the phone from the socket in the wall and plug it into the livebox connection.
    Is there a phone out that can handle 2 lines (one to go out and one to come in ??) at the same time (or switchable as i never receive incoming on the Livebox)
    I know its a long shot, but it would save m ebuying another phone and have handsets lying around.
    Ta
    :confused:
  2. Vogon64
    Vogon64
    Jul 31, 2006
    121
    +9
  3. hot-fuzz
    hot-fuzz
    Dec 13, 2005
    6,086
    +593
    Cheers for that.
    I have just forked out £15 on a BT Equinox Phone so we have one for outgoing and one for incoming.
    Hmm, im going to look at the one you suggest, may require another purchase.
    Ta
    :thumbsup:
  4. ancientgeek
    ancientgeek
    BT converse 2025, BT Converse 1400; probably lots of others.
  5. danielcsw
    danielcsw
    in case you're still looking, i have one of these...
    MOD EDIT
