is there £10 differance in value for spartacus?
Discussion in 'Movie Forum' started by Gadjet, May 31, 2004.
  1. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    I am going to buy Spartacus, but with the R1 film being £10 more expensive is that price really worth the diffe :rolleyes: rence?. It is quite a big gap between R1 and R2. Reading the description they both seem the same except R1 is 10 mins longer on the film length than R2.
    Has anyone got the film to express their veiws.
    Your help will be much appreciated before I buy the film.
    Phill
  2. anephric
    anephric
    Mar 23, 2002
    1,048
    Derby
    +147
    The R1 has the film on one disc, not spread across onto 2. Extras are the same (ones that Criterion originally assembled, I might add). The film's runtime is exactly the same if your factor ntsc speedup into the equation. I prefer the R1 as I don't have to change discs and the packaging is far nicer.
    regards,
    anephric
  3. Confucius
    Confucius
    Feb 1, 2001
    2,148
    Oxford
    +132
  4. Markmw
    Markmw
    £10 difference? Where are you buying the R2?!
    The R1 is £14.99 at cd-wow
    There are a couple of threads already about the difference and prices so check those out.
    Essentially the price now is roughly the same, although the R2 will no doubt come down to a tenner in the future. R1 has the film on one disc and better packaging, the R2 had DTS.
  5. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    T :thumbsup: hanks for your help, I was buying it from Play USA. Not now, I will buy it from CD-Wow. Did not know about Pal speed up either. Great help.
    many thanks,
    Phill
