kevlar
I currently have an eltac sub which hums quite a bit. It is a design fault apparently, they are all the same. I've put up with it long enough and have finally been given the go ahead to replace it
. I'm thinking of getting the XLS200 MK2, I just want to know is it silent when it is not producing bass? I would not be happy if I ended up with another humming subwoofer. Also is there any performance difference between the forward firing/down firing models?
Thanks in advance
Kev
Thanks in advance
Kev
