Is the Samsung LW32A33W HDTV ready?
Discussion in 'LCD & LED LCD TVs' started by sn00p, Apr 7, 2005.
  1. sn00p
    sn00p
    It's smaller brother, the LW26A33XW is HDTV ready
    http://www.unbeatable.co.uk/CatalogueItem_19355.html
    and this European Samsung site says the LW32 is also HDTV
    http://www.samsung.com/at/products/tv/flatpanellcdtv/lw32a33w.asp?page=Specifications
    However I can't find any mention of it being HDTV ready on any UK sites?
    Here are the official pages from the UK Samsung siite
    LW32A33W - http://www.samsung.co.uk/cgi-bin/ec...tertainment/TV/TFT+LCD+TV&prodID=LW32A33W/XEU
    LW26A33W - http://www.samsung.co.uk/cgi-bin/ec...ertainment/TV/TFT+LCD+TV&prodID=LW26A33WX/XEU
  2. jimg
    jimg
    Jul 4, 2004
    826
    +58
    You need a HDMI or DVI-HDCP input, the 32" says no and the 26" says it has the DVI-HDCP.
  3. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    The Samsung LW32A33 has HDMI (which automatically makes it HD ready) & DVI, can confirm this as I have looked at one in Currys, also theres a thread on this which I commented on yesterday, a member has purchased one of these and writtem a mini review.
  4. jimg
    jimg
    Jul 4, 2004
    826
    +58
    I guess Samsung should update their web site and make it clearer.
  5. sn00p
    sn00p
    Yes it's HDTV Ready. :thumbsup:
    Thank you for contacting SamsungElectronics.
    [Solution]
    We are pleased to confirm that the LW32A33WTV is HDTV ready.
    I hope this has been of some assistance to you. If you do have any
    further queries, please do not hesitate to contact us.
  6. MorseKode
    MorseKode
    But it doesn't do 720p at 50Hz... So isn't that kind of a contradiction in terms? Or have I confused my terms..? :confused:
  7. sn00p
    sn00p
    After reading Damian Arstall's review I don't think it's even worth considering.
    Shame, it's the nicest looking set I've seen.
  8. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    Alternatively the SAMSUNG LE32A41BX here
    http://www.qed-uk.com/?i=12kW1G0DkA...31&prodlist_p=1
    This 32" LCD is true 16:9 (1366x768) as opposed to the LW32A33W which is 15:9 (1280x768) the only feature missing is the HDMI although it does have DVI (HDPC_ enabled. Oh and it costs £1063 + del.
  9. sn00p
    sn00p
  10. YellowCows
    YellowCows
    Dec 15, 2002
    141
    It does indeed accept 720p @ 50Hz. So does the LW32A32W (which has only one DVI input, but it's DV-I (i.e. both digital and analogue) and HDCP-ready).
    HTH
    Moory ;)
  11. MorseKode
    MorseKode
    I emailed Samsung and they told me the LW32A33W doesn't do 720p/50Hz. Unless you are saying they don't know their own product? (not impossible! :)).
  12. barongreenback
    barongreenback
    Mar 30, 2005
    980
    +60
    Samsung told me it does accept the 50Hz signal at 720p as well.
    By the way, this isn't a bad set for the money. I was a little concerned to start with but after pairing it with the right DVD player things improved a hell of a lot. The final thing was to play around endlessly with the various picture settings to get a good result. It took some time but I got there in the end. Don't let Damian's review put you off.
  13. MorseKode
    MorseKode
    Thank you for contacting Samsung Electronics regarding the 32'' LCD TV, LW32A33W.
    Is is correct that this model of TV will not support 720p at 50hz ,it will only support this at 60Hz, but will support 576 interlaced and progressive scan and also 1080i at 50Hz through Component!
    Can anyone actually verify/deny this??!
