Sorry nobody answered you! The answer is yes - Have you seen one without? I can post a picture if not.ok it is!
It’s not in a home environment, it’s wall mounted in a store - is that ok? Hopefully it will just give an idea of perspectiveyes pls - thanks
Sorry it’s been so long, had a busy day!Yes pls - if you do have one would you be able to measure the top two vesa holes from the bottom edge of the TV pls as I need to move my existing mount down.
