Is the Panasonic E85 OK for Multi-Region?
Discussion in 'Blu-ray & DVD Players & Recorders' started by mdawkins, Feb 4, 2005.
  1. mdawkins
    mdawkins
    Aug 17, 2004
    130
    16
    Sydney
    I am looking at buying the Panasonic E85 as it appears to meet all of my needs, but I just want somebody to clarfiy if it works OK as a multi-region player, will it automatically play NTSC discs or do you have to change a setting in the menu somewhere and change it back again to play Region 2 discs?
    Martin.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    it can be "modded" but it seems some are automatic and some require manual change over. (this may be just for RCE disks)
  3. mdawkins
    mdawkins
    Aug 17, 2004
    130
    16
    Sydney
    What I meant to say was, do you have to change a setting in the menu to NTSC and then back to PAL when playing Region 2 discs?
    Martin.
  4. bigsby
    bigsby
    Apr 14, 2004
    268
    +9
    I've never had to change a setting on my E85 to watch a R1 (or indeed R3) disc. I'm not sure where this urban myth originated, but I suspect it was from someone who:
    a) Didn't have their machine set up correctly
    b) Didn't know how to use their machine.
    Either way it's a load of crap. Hope this helps!
  5. Drogon Mejas
    Drogon Mejas
    Jun 26, 2004
    Purchased my E85 in August last year and had it put to multi region by the supplier. No need to change any settings all regions play fine.
