Is the Nunchuck included with the Wii console?
Discussion in 'Nintendo Wii-U & 3DS' started by PaulD2004, Jan 3, 2007.
  1. PaulD2004
    PaulD2004
    Jun 13, 2006
    1,089
    63
    +132
    This is probably a stupid question but is the nunchuck attachment included with the Wii console?
    Also do you need to purchase a SD memory card to save games?
  2. MonkeyKnuckle
    MonkeyKnuckle
    Dec 8, 2005
    6,519
    Portsmouth
    +718
    Yes a Nunchuck is included.
    You can buy an SD card but I don't think you need one anytime soon. The Wii has 512Mb of built in memory.
  3. T Henry
    T Henry
    Feb 9, 2006
    301
    Berkshire
    +6
    Yes you get a nunchuk and no you dont need a memory card to save games. :thumbsup:
  4. PaulD2004
    PaulD2004
    Jun 13, 2006
    1,089
    63
    +132
    Thanks,
    What would you recommend I get for the Wii then apart from an additional controller? Should I bother getting another nunchuck?
    I have one coming on Saturday and want to be ready to go.
  5. Andrew K
    Andrew K
    Oct 14, 2004
    3,392
    +608
    If you want to play two player Boxing or Red Steel then you will need a second nunchuck.
    The nunchuck is included with the main system but is not included when you buy a second controller.
