Is the JVC RGB problem on 100Hz sets only??
Discussion in 'TVs' started by Paul_J_Smith, Dec 31, 2002.
  1. Paul_J_Smith
    Paul_J_Smith
    Dec 16, 2002
    37
    I have noticed that there are several postings regarding dark RGB on the JVC 28/32 WFT1 and WFR1. I am just about to order a JVC AV32R25EKS and was wondering if this also had the same problems or if it was something that had been fixed on this model? Is this model newer than the WFT1? Is the RGB contrast adjustable on the R25/T25? As far as I can see the WFR1 is 100Hz whereas the R/T25 is 50Hz - does this make a difference?
    Many thanks
    Paul
  2. Squirrel God
    Squirrel God
    I had dark RGB on the AV28R25, the 28" model of the TV you're getting. It was a 50Hz set.
