Is the Denon A/V-F100 worth having?
Discussion in 'Home Cinema Speakers' started by Malakh, Jan 12, 2002.
  1. Malakh
    Malakh
    Jan 3, 2002
    29
    Hi guys,
    After having the evils of the Sony DAV systems drilled into me I went into my local Hi-Fi specialist and the guy there said that, while all-in-one systems are bad, the Denon A/V-F100 is actually a decent one. He demonstrated it and it all sounded pretty good to me. The SCAV-F100 NXT Flat speakers that come with it are only 20W or so but they sounded impressive. Has anyone got this system and would recommend it? Is the sound as good as it seemed? Are the speakers good?
    I heard some people had mixed feelings about the included DVD player.
    thanks for your help
    M
  2. ZZR
    ZZR
    See link below for some reviews
