Is the Cambridge 540R good enough for a couple of B&W 704?
Discussion in 'AV Receivers & Amplifiers' started by SRam, Sep 8, 2004.
  1. SRam
    SRam
    As the topic says I'm looking to buy a HIFI/HC system for about 50/50% use.
    I'm inclined to buy the 704 but I'm wondering if a Cambridge 540R would be enough to drive them or if I should go with a bigger model in which case I would consider downgrading the 704 to the 600 series.
    Tks for your replies.
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,195
    2
    +3,667
    It will struggle with a speaker that big as there is a fair old price imbalance between the two and most B&W designs are current hungry.
  3. Radiohead
    Radiohead
    Dec 24, 2001
    4,396
    Amazingstoke
    +432
    Speakers of that calibre need a better amp than that to do them justice.
    As a minimum I'd be looking at a SR7400, RX-V1400 or 2805.
  4. SRam
    SRam
    Maybe a NAD T753? I could perhaps stretch my budget for that much is the 704 are really worth it. What do you think?
  5. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,195
    2
    +3,667
    I work for another speaker manufacturer and am not B&W's number 1 fan so won't comment further. The T753 is a nice receiver though. Perhaps a little expensive for what it is.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I would suggest you look at S/H or Exdemo Rotel and HK kit as these can deliver thelarge current demands that B&W speakers can make. HK AVR 4500/4550 would be up to the job and should be found for well under £500 if anyone has any stock left. Newer HK will cost you a lot more for very similar performance and a lesser build quality.
  7. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    I'm blowing my SR7400 trumpet again and second the earlier suggestion :D
  8. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    SR7400, RX-V1400 or 2805 are at a good level.
    Sr7400 for better sound match!
