Is the AE700 ceiling-mountable
Discussion in 'Projectors, Screens & Video Processors' started by calvinhobbes, Sep 23, 2004.
  1. calvinhobbes
    calvinhobbes
    Hi All
    Does anyone know whether the AE700 is ceiling mountable and if so, where to get a good cheap mount?
  2. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    253
    Surbiton
    +6
    I won one from Ebay, had the pj on the ceiling for little under 48 hours, then took it down.
    Ebay
    If you want one, you can buy it for £50 delivered? (the item is reserved at £57 + postage)
    Let me know,
    Chris
  3. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    4,883
    Falkirk, Scotland
    +843
    What was the reason you decided to take it down ?
    Keith Hurst
  4. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    253
    Surbiton
    +6
    Keystone correction, nuff said.
    But with an AE700, you should be able to lens shift the picture to the correct position.
    See my post a bit further down the forum.
  5. gwc
    gwc
    Oct 21, 2003
    497
    Wokingham, Berkshire
    +7
    What was the problem with the keystone correction. Angle to great?
    gwc
  6. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    253
    Surbiton
    +6
    Yes, the angle was too great. It'd been fine if I was using a larger screen, as the throw would be longer. Also my screen is very low down due to being in the loft conversion (about 35cm from the ground).
  7. gwc
    gwc
    Oct 21, 2003
    497
    +7
    Hi Chris,
    Bit worrying as I am current getting a loft conversion with the aim of it being a cinema room. Could you tell me the height of your loft room and the size of screen you are using.
    As i may need to rethink where the PJ is going to go.
    gwc
  8. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    253
    Surbiton
    +6
    Hi, see my other post for more pics . . .
    Again, since I can't find my tape measure, the room is about 7.5' high (in the peak) and the screen is 60".
    Hope this helps . . .
