Hello all, I'm thinking way in advance here as I won't be buying until August/September so things may well change by that time.
I'm looking for a plasma between 32" and 42" - 37" would prob be the ideal. I want a plasma that doesn't have a very large surround. I dont't need speakers or a tuner (not that it matters if one is included - although removable speakers will make the tv look smaller I guess).
I will be using my Denon 1910 DVD player (which has DVI out) and my thomson DHD-4000 freeview PVR.
I would want to get a plasma that is HD compatible even though I doubt I'll be getting sky. I know plasmas and lcds are good with high quality sources - like DVD's but not good with standard definition broadcasts. I keep hearing about scalers like the DVDO iScan HD+ which sound good but expensive and also Gordon ISF and his calibrations keeps popping up in threads
I also want some 5.1 surround sound - I was thinking something like yammy 750SE and some MS Genies.
I need a stand for the tv and other equipment (probably go for somrthing like the £100 Kenmark one) and I need all the cables.
Right my budget, and try not to laugh, is £3000
I would happily by the audio stuff second hand, maybe if I go with the yamaha amp I could get it from Germany and the speakers second hand somewhere.
Anyway, is that sort of setup remotely possible with my budget or is it simply wishful thinking?
Thanks, Nick.
Thanks, Nick.
