Is Someone Uploading From My PC ?
Discussion in 'Computer Software & Operating Systems' started by J80FAB, Sep 15, 2007.
  1. J80FAB
    J80FAB
    Jun 19, 2005
    1,843
    48
    +70
    Erm.... yes well I'm no expert at these things but I'm getting slightly annoyed as my PC has recently started to upload at times for no apparent reason.
    Is it possible that someone has 'hacked' into the PC & is uploading stuff from it :confused:
    When uploading starts I reset the PPP connection with my ISP which usually makes it stop until it starts again.
    I did recently update the 4oD (4 on demand) software & the uploading if I'm not mistaken seems to have started after that. Or it just might be a coincidence.
    Any advice would be appreciated.
    EDIT:
    Sorry forgot to mention I'm running Win XP Home Edition.
  2. Rattty
    Rattty
    Dec 30, 2006
    64
    +6
    Install a firewall like Zone Alarm, this will show all network traffic and you can then stop any 'odd' activity.
  3. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    How do you know someone is uploading from your PC? What (if any) tools/software are you using?
  4. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    I would just look at my router lights ;)
  5. J80FAB
    J80FAB
    Jun 19, 2005
    1,843
    48
    +70
    Well in answer to the above my router is next to my monitor so I can see the lights flashing :D, I have NetMeter installed which shows upstream activity when there shouldn't be any & of course my LAN icon at the botton right will show continuous activity with its flashing screens, that's how I know !
  6. Decadent Fool
    Decadent Fool
    Dec 27, 2006
    546
    28
    Shropshire
    +33
    As previously mentioned, install ZoneAlarm and it will tell you the desired destination of anything trying to access the net
  7. Steve.J.Davies
    Steve.J.Davies
    Nov 14, 2004
    2,995
    83
    +199
    in the maentime the output from a
    netstat /a
    could prove informative.
  8. J80FAB
    J80FAB
    Jun 19, 2005
    1,843
    48
    +70
    I've tried downloading/installing ZoneAlarm but I keep getting an error message : 'setup was unable to find the msi package or patch' :confused: and then there's a URL given :rolleyes:
    EDIT:
    I assume I'm looking at the correct ZoneAlarm as there seem to be a couple around.
    Can someone please direct me to the correct one.
  9. Ianfromnotts
    Ianfromnotts
    May 16, 2003
    2,760
    Nottingham
    +174
  10. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    Install a decent firewall and then recheck your findings. It could be Microsoft services auto updating.
  11. J80FAB
    J80FAB
    Jun 19, 2005
    1,843
    48
    +70
    I have the automatic Windows Update feature turned off & always perform it manually as I prefer it that way.
    In any case with Windows Update it is a case of mass downloading rather than uploading.
  12. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    does 4OD work like the BBC one that uses a sort of Bit torrent affair to download programs, maybe it's that that uploading.
    Curly
  13. Steve.J.Davies
    Steve.J.Davies
    Nov 14, 2004
    2,995
    83
    +199
    in the mentime the output from a
    netstat /a
  14. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    Yes, but the Windows Update components auto update themselves - or else you would not be able to use WU/AU/MU. They can not be set otherwise.
    Anyhow I don't think it is that.
    Have you found any odds file on your computer? If they are uploading from your computer, your bound to have something there that isn't supposed to be there.
  15. fortean
    fortean
    Nov 28, 2004
    825
    Chorley
    +71
    Have a look if you have a service running called Kservice. This is a peer to peer service that is used to distribute content for BBC iPlayer, 4OD, Sky Movies, etc.
    You can stop and disable the service in the services tab when you are not downloading anything.
    Right click the My Computer icon and select Manage.
    Near the bottom of the list on the left you will find Services and Applications; Open the list to see Services. Click this and all the Services will be shown on the right hand side.
    Find Kservice, double click it, stop it, then change the Startup type to Disabled.
    You may need to enable it, change to manual, then start it to download content though.
  16. J80FAB
    J80FAB
    Jun 19, 2005
    1,843
    48
    +70
    As I mentioned in my opening post I did update the 4oD software as I was prompted to do so therefore it's possible that this has had some effect.
    I've installed the ZoneAlarm as recommended and currently one application which keeps popping up saying it 'wants to connect to the internet' or 'act as a server' or something like that, is described as a Delivery Manager Service. And further investigation shows that it is indeed Kservice being used by 4oD.
    I've done as you said so it will be interesting to see if it makes any difference.
    As you mentioned disabling Kservice makes access to 4oD for example not possible. Setting it to 'Manual' makes ZoneAlarm respond by asking if I want to allow or deny the Delivery Manager Service access to the internet.
    I've disabled it for now to see what happens. And probably will have to enable it if I want to use 4oD.
    Thanks for the info.
  17. richard plumb
    richard plumb
    Jan 27, 2002
    14,524
    Windsor
    +1,054
    Kservice will be the culprit. BBC, 40d and sky anytime all use this to save their bandwidth costs by using P2P to share the load.
    So yes, your computer will be uploading all the time when your internet connection is normally idle.
    One reason I don't install those apps. I'd almost pay them a little fee to use normal downloading.
  18. J80FAB
    J80FAB
    Jun 19, 2005
    1,843
    48
    +70
    Mmmmm...... yes from initial observations it would seem that Kservice is indeed the culprit.
    I just used 4oD & watched something I downloaded a couple of days ago. I had to cover the router LEDs because they were putting me off what I was watching !!!
    Anyway when I stopped Kservice as suggested earlier in this thread the frantic upload activity also stopped & 4oD disappeared :rolleyes:
    I've never really taken much interest in P2P so don't know much about it. Why does uploading from my end take place and what's the significance of it ?
  19. Steve.J.Davies
    Steve.J.Davies
    Nov 14, 2004
    2,995
    83
    +199
    It takes bandwidth and increases your load. if you sail close to a FUP it may not be for you.
    main significance in sharing apps is that you need to make sure you lock down what directories they can upload to the net from.
    If it is unrestricted then 'all your files are belong to us'.
  20. J80FAB
    J80FAB
    Jun 19, 2005
    1,843
    48
    +70
    Sorry don't quite understand your explanation & why something like Kservice would want to use one's upstream bandwidth :confused:
    What's an FUP ?
  21. Steve.J.Davies
    Steve.J.Davies
    Nov 14, 2004
    2,995
    83
    +199
    Phased around P2P in general (in line with your question).
    FUP - Fair Use Policy. ISPs use this stop folks hogging comms lines.
    Sharing apps run both ways - besides letting you download from lots of places they also let lots of places download from you.
    Sharing apps use a directory structure to store downloaded files - mostly you have to tell them where to put downloaded files when you install/set them up.
    For uploade files 9from your machine to other P2P sharers out there) you need to tell your P2P app what directories you will allow to be read by these unknown remote machine from all globe. If this information is not locked down it can easily be that a P2P app is allowing all these remote shares to read ALL your files.
  22. J80FAB
    J80FAB
    Jun 19, 2005
    1,843
    48
    +70
    :oops: Just realised what FUP stands for - doh !
    I think I know what you mean now.
    A few days ago I used 4oD to download some programmes to watch later rather than watching them being streamed over the net - don't know if it makes a difference either way.
    Anyway as the downloaded content from 4oD is on my hard drive I am assuming that my PC is being used as a 'server' to distribute the downloaded stuff to anyone wanting to download/stream the same material to their PC thus not clogging up the 4oD's servers.
    This would make sense because the ZoneAlarm firewall does report - when Kservice is enabled - that the Delivey Service Manager (Kservice) wants to use my PC as a 'server'. Brilliant, not !
    I think I might consider removing 4oD altogether from my PC.
    The interesting thing is that 4oD does charge for viewing some programmes whilst a handful are free. Surely it would be a bit off hand for them to use someone's PC for P2P after that person has paid to download/watch stuff from the 4oD site.
  23. J80FAB
    J80FAB
    Jun 19, 2005
    1,843
    48
    +70
    Was wondering if someone could help again :lease:
    Seem to have got to the bottom of the uploading business - Kservice.exe application which installs with Channel 4's 4oD service and uses your PC as a server for P2P.
    I've disabled Kservice so that it doesn't work.
    However now when I start up my Windows Messenger Live the blighter starts doing the same :suicide:
    OK it may not start straight away but after some time has elapsed uploading begins :rolleyes: If I close Windows Messenger it stops.
    Anyone have any idea what's going on in this instance :confused:
  24. Steve.J.Davies
    Steve.J.Davies
    Nov 14, 2004
    2,995
    83
    +199
    Disable it. run scans.
    you have been in p2p land - it pays to check you really are clear.
    of course while these uploads are happening the output from a
    netstat /a
    could prove informative....
    Should add that TCPVIEW andor Process Explorer (both free) can give a lot of good info. But if it is a nasty it may hiding..
  25. J80FAB
    J80FAB
    Jun 19, 2005
    1,843
    48
    +70
    I never ran netstat /a when you previously suggested as I did not know what this was. I've just run the command at the command prompt so now I know.
    I've actually uninstalled ZoneAlarm as it was slowing things down. It nevertheless did not seem to report anything when Windows Live Messenger started uploading :rolleyes:
    Will reinstall it & monitor Messenger with that & the recommended netstat.
    Tried the recommended Sunbelt Firewall. Doesn't slow things down on my PC but drove me nuts with its continuous pop-ups warning of this & that.
  26. Steve.J.Davies
    Steve.J.Davies
    Nov 14, 2004
    2,995
    83
    +199
    pop ups happen on anew firewall install while you build your ruleset. then things quieten down.
    trouble with p2p apps is that each IP (inbound or outbound) gives a pop up if no rule for it. A lot of folks end up giving their p2p apps unfettered access through the firewall so reducing the pop-ups. And so negating the firewall - cos they just drilled a hole in it for their p2p app. If you 'HAVE' to use p2p stuff then research a safe setup for it. IF one exists...and don't be logged on as (or 'run as ') Admin...
  27. edward
    edward
    Apr 2, 2003
    878
    32
    Reading
    +33
    If you do netstat/o it will show much the same as /a but the 5th column shows you the PID as well.
    If you don't recognise any of the addresses shown, do a ctrl/alt/delete to get the task manager up, go to the process panel, click the header of the PID column to sort them into order and then scroll down until you find the PID you want explained - it will show you what image is running. If you don't recognise the image name, put it in google and you'll get an explanation.
    I've got a freebie called Net Medic on my desktop so I can see when stuff is coming and going and how much bandwithd its taking up.
    In my case, it was Skype that was the culprit.
