Is Sharp LC37HV4E capable of Prog. Scan?
Discussion in 'Plasma TVs Forum' started by dnesdlrow, Sep 7, 2004.
  1. dnesdlrow
    dnesdlrow
    Aug 17, 2004
    13
    Is the Sharp LC37HV4E capable of taking and using a progressive scan input from a Tosh RDXs-32 DVD recorder? or am I talking rubbish. If so does it make a big difference?
    Also I've seen people moan a bit about the pixelation of this screen, is this just because it is such a high def screen showing low def images (pal etc..)? Would it be any worse than a similar sized plama?
    Thanks.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Yes it will take PS signal it actually display everything in PS as it is a progressive only display........... ie it wil deinterlace any signal you give it. Yes pixelation will be worse.
