Is room too big for sub/sat?
Discussion in 'Home Cinema Speakers' started by catesby, Jan 26, 2005.
  1. catesby
    catesby
    Jan 5, 2005
    49
    Hello
    I'm looking to put some kit into a room that is 6m x 6m.
    Is this too big for Kefs Eggs or the Castle Compact set (the speakers I'm thinking of) or indeed for any sub/sat? Would Kefs 5005 be a better bet? Someone in another thread said they would run out of puff in a big room - is this true?
    Any advice welcome.
  2. SKA.face
    SKA.face
    6mX6m is huge,alot of area to fill: I wouldnt consider KEF eggs at all.I would think you'd need a powerful amp also:iwould go for floorstanders and sub,but the depends on your budget and it doesn't cause domestic riots
