is r2 gladiator dts (5 chanel) only
Discussion in 'Movie Forum' started by mick23, Jul 8, 2002.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    bought r2 gladiator from woolies soundtrack dd5.1 and dts i assume the dts on this disk is simular to the dd5.1, i (know r1 is discreet etc) i hired gladitor some time ago sound from rear speakers etc sounded better as i recolect than this new disk does, cannot remember how amp was set at that time though (matrix etc) thank you
  2. kevb
    kevb
    May 16, 2002
    1,099
    41
    About
    +3
    As far as I know it has a matrixed DTS-ES and a DD-EX soundtrack.
    On my set-up I have a more obvious centre rear from the DD soundtrack. The centre rear is there on the DTS track but it is slightly more subtle.
  3. Shirker
    Shirker
    Oct 30, 2001
    54
    9
    Leeds
    As far as I can remember ther's a menu option to swap between DD and DTS
  4. t-force
    t-force
    May 2, 2001
    1,863
    Southampton, UK
    +151
    If I remember correctly, the Region 1 edition uses dts-es discrete, which is true 6.1, while the Region 2 is dts-es matrix, with the rear channel matrixed into the surrounds.
  5. Idonex
    Idonex
    Jul 11, 2002
    15
    I have Gladiator and T2:SE in DTS (region 2). Both are labelled as DTS 5.1 but T2 automatically turns on the Matrix 6.1 decoder whereas Gladiator just stays in normal DTS.
  6. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    i got a standard dts gladiator.......no matrixed or es of any variety......if i'd known that when i bought it from play i would have looked elsewhere!
    ad
  7. Jase
    Jase
    Mar 16, 2001
    10,815
    United Kingdom
    +2,693
    R1 Gladiator is DTS ES Discrete
    R2 Gladiator (UK) is DTS ES Matrix despite the 5.1 on the packing, engage the surround back channels on your amp and you´ll be ok (assuming you have an amp/receiver/processor with EX/ES decoding).
    R2 Gladiator (Spain) NO DTS!:rolleyes:
