is progressive scan what i need?
Discussion in 'Blu-ray & DVD Players & Recorders' started by nate-x, Dec 11, 2002.
  1. nate-x
    nate-x
    I recently purchased a Samssung 27" flat-screen analog TV. The set does not have 3:2 pulldown although it does a 16:9 compression (similar to Sony's). It is a great piece of equipment. I currently have an older model Sony DVD player (non-progressive scan) and would like to upgrade. I am using Monster component cables and the picture looks fantastic. But, I know it could look better.
    Will adding a progressive scan DVD player (3:2 pulldown) add a more filmlike quality or will it not matter on my analog t.v.?
  2. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    Unless you tv is actually capable of handling a progressive signal, then it's of NO use to you. If your tv is capable of handling a progressive signal (3:2* pulldown is handled by the chip in the progressive dvd player) then you'll see an improvement in the picture.
    3:2 pulldown is to do with how the dvd player handles the video fields/frames and is nothing to do with the 16:9 aspect of the tv.
    Brian
  3. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    Portsmouth / Middle East
    +77
    nate-x
    Do you own a blue Ford Escort?
  4. nate-x
    nate-x
    so there is absolutely no picture enhancement when using a progressive scan over a "regular" DVD player playing on an analog tv?
  5. MarkB4506
    MarkB4506
    Nov 16, 2002
    Glasgow
    +4
    There'll be absolutely no picture at all nate!
    Feeding a progressive signal into an interlaced only display will result in no image!
