Is PAL PS needed??
Discussion in 'Blu-ray & DVD Players & Recorders' started by JayBee, Jun 6, 2004.
  1. JayBee
    JayBee
    Oct 22, 2002
    Was looking into getting a progressive scan DVD player, and noticed one that converted PAL signal to NTSC progressive and obviously outputted NTSC as NTSC progressive.
    This got me to thinking. If the DVD was hooked up to a SD(?) plasma screen that only has 480 lines anyway, would it still be worth getting a player that supported PAL PS. Or would it actually be better to have a player that converted to NTSC PS?
    Thanks for helping a confused newbie :)
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    you would be relying that the conversion is done remotely well..... it isnt beyond possibility that it is done poorly enough so as to make things look awful
    ad
  3. JayBee
    JayBee
    Oct 22, 2002
    So by having a player that outputs both PAL & NTSC progressive, I am free to either let the screen (plasma) do the conversion or even an external scaler(?) if I so choose?
    Thanks. Thought it'd probably be better to allow things to come out of the player as natural as possible, but just wanted to check.
  4. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Yeah you are right, though if you were using an external processing solution you would just use an interlaced signal and let the processor deinterlace
    ad
  5. samhain
    samhain
    Apr 1, 2004
    2,773
    South West Scotland
    +128
    If you have a PAL to NTSC progressive coverter then I think I am right in saying that the Panny PW6 with DVI would actually work this way.
  6. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    hmmmm that would be hopeful.... chances are the output would be ntsc resolution at pal refresh rate.... which is a problem were it the case. As far as im aware, the dvi can handle pal progressive, it is 480p at 50Hz is the issue
    ad
