Is my wireless router broken?
Discussion in 'Networking & NAS' started by Reepicheep, Feb 1, 2009.
  1. Reepicheep
    Reepicheep
    Aug 5, 2002
    583
    28
    Leicestershire
    +51
    I'm on Virgin 10M Broadband and just recently I've been having major problems with my wireless connection.
    If I plug my Virgin modem direct to my desktop PC I get close to 9.5Mb (according to Broadband Expert speed test). So I assume there is nothing wrong with my Virgin connection.
    When I add in my Belkin wireless router the speed drops on my both my desktop PC and my wireless laptop to anything down to 0.3Mb :eek:
    Is my router knackered or could it be something lease in the router settings that's causing the speed drop off?
  2. graystreet
    graystreet
    Dec 15, 2004
    1,089
    83
    Littlehampton, West Sussex
    +261
    When you're connecting via your router are the PC and laptop both connecting wirelessly or is the PC cabled?
    If both are connected wirelessly, try connecting one via an ethernet cable.
    What's the model number of your Belkin router?
  3. Reepicheep
    Reepicheep
    Aug 5, 2002
    583
    28
    Leicestershire
    +51
    Belkin model is: F5D7231-4 2000
    Desktop PC is wired, laptops are wireless.
  4. Delvey
    Delvey
    Jul 20, 2008
    9,305
    Manchester
    +2,932
    could be incorrect settings in the router. And reboot everything after you add a router into the network
  5. graystreet
    graystreet
    Dec 15, 2004
    1,089
    83
    +261
    Someone with a similar problem here mebbe worth a read.
