Is my Wii broke? (remote issues)
Discussion in 'Nintendo Wii-U & 3DS' started by secombe, Dec 21, 2006.
  1. secombe
    secombe
    Dec 7, 2006
    94
    Wiltshire, UK
    +53
    One of my remotes wouldn't work today (number 1 light would flash, stay constant and then go out as soon as I moved it) so I assumed the batteries were dead.
    To check I took the batteries from the one that was working and tried them in the faulty one, still no joy. So then I put fresh batteries in both remotes, and now nothing works!
    Doing the standard synch procedure, holding down red button on console and remote as required and on both remotes now all 4 lights on the remote just flash indefinitely (I gave up after about 3 minutes), am I missing something?!
  2. Member 55145
    Member 55145
    Jan 18, 2005
    12,082
    +3,481
    turn console off. pick your main remote and press power button on it, this should turn wii on with your remote syncing to player 1.
    press home button and i think it gives your instructions for other remotes
  3. KinkyAffro
    KinkyAffro
    Dec 13, 2005
    1,508
    63
    South Yorkshire
    +164
    I also had this problem.
    I unplugged the console at the wall in the end and when i powered back on everything, including remotes, worked ok again :thumbsup:
  4. SuperKip
    SuperKip
    Aug 22, 2006
    517
    kent
    +16
    When doing the Sync I had the same problem. Then I found that if you press the button on machine and remote just once at the same time (without keeping both buttons pressed in) then it seems to sync it straight away.
    I tried about 5 times keeping the buttons compressed on both remotes before this and it wasn't working. I thought i'd broken something already:rolleyes:
