Is my wall mount safe?
Discussion in 'Home Cinema Buying & Building' started by Edxu, Feb 20, 2014.
  1. Edxu
    Edxu
    Feb 20, 2014
    4
    Los Angeles, California
    I have a 46 pound 32inch screen flat screen I recently mounted to the wall. The mount was built to hold 160 pounds but after a few days I noticed the top screws have come a bit loose. Not enough to wobble the whole thing but I can see a slight give in the tightness. I mounted it to studs and everything. Am I safe or should I be worried? What can I do to keep it tight?
