Is my tv on its way out?
Discussion in 'General TV Discussions Forum' started by TurnipFarmer, Jul 13, 2005.
  1. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,259
    38
    Hertfordshire
    +5
    My tv is failing to turn on now sometimes, I have sound but no picture.
    I have also noticed that the picture on the screen has become smaller by about 2-3cm on all sides and no matter what I do it seams to stay the same
    Any ideas guys?
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Make and model number, please?
  3. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,259
    38
    Hertfordshire
    +5
    The make and model number is
    Samsung - WI-28W6VD
    Any help would be great
  4. nig28
    nig28
    I assume that you mean the picture gets smaller from both sides, this is called an east/west fault, not a uncommom problem.
    Not sure about the cost of repair but I would imagine less than £90
    Nigel
  5. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,259
    38
    Hertfordshire
    +5
    It could be but it might not be, as with some tvs you can adjust the size of the screen our tv wont allow your to do it anymore
  6. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Hi, you say the picture is getting smaller by 2-3 cms on all sides ? If that's the case then you may have excessive EHT (very unlikely) or psu fault. Could be a faulty connector or component. Difficult to say how much it would be to repair. If the tellys 'old' it may be a common and well known fault in which case a reputable repairman may be able to give you a rough quote over the phone. Regards, yt.
