Is my th42pw6 receiving component signal
Discussion in 'Plasma TVs' started by darkness1, Jul 1, 2005.
  1. darkness1
    darkness1
    Apr 8, 2005
    93
    Hi, I've recently bought a Toshiba SD9500 dvd player region 2. Now this is supposed to send a progressive scan signal. Now i've heard that theirs been problems with this player.
    My problem is how to access the service menu on my TH42pw6 panny panel to check for progressive signal. I have connected the box up with panny's progressive box in the back of the set.
    Please help.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,413
    The Borders
    +2,590
    darkness1
    You'll have to access the Service Menu to have a look at what signal your Display is receiving on the selected Input.
    I take it you have a 3RCA to 3RCA or 3BNC cable between the DVD player and the RCA or BNC board in your Display - you'll also need to ensure your DVD player is set to Output a Progressive signal.
    Best regards
    Joe
  3. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,183
    London
    +399
    What problems you having with the SD9500 ? Have you got v2.7 firmware on it ? That is Pal Progressive enabled :smashin:
    Zoom 6-0-6 Zoom
    You will see what version you have on it from that. If you stick in a PAL disc with PS enabled the blue light on the panel should be on. You will be getting PAL PS all the way :)
  4. darkness1
    darkness1
    Apr 8, 2005
    93
    Looks A okay then. I have firmware v2.7 and the ps blue light is on so :thumbsup:
    ps I found a company that can multi region the player also for £60. :smashin:
  5. diabolik
    diabolik
    what is the company?
