Is my Sony 725D Dying?
Discussion in 'Blu-ray & DVD Players & Recorders' started by UlricVonLichtenstien, Feb 4, 2002.
  1. UlricVonLichtenstien
    Just recently, I have noticed that my 725 shows bands of light and dark on scenes where there is a lot of movement. I can (usually - sometimes it takes more than one go) get rid of it, by tuning the DVD off, then on again.
    It's connected to the telly (Phillips 42" plasma) via the 2nd RGB scart, and everything is set for RGB. It's a Techtronics chipped unit which is now about 2 1/2 years old
    Any ideas what could be causing this?
    BTW, it dosen't auto switch to the sony logo on when it's switched on anymore...
    Jason
  2. UlricVonLichtenstien
    ....Anybody ....Anybody
  3. UlricVonLichtenstien
    Can nobody help?:(
  4. Guest
    uk.media.dvd ?
  5. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,463
    United Kingdom
    +1,921
    Seems like theres something wrong with it so you´ll need to get it looked at, either where you bought it from or at another place.
