Is my Sky Plus Knackered?
Discussion in 'Sky Digital TV Forum' started by Nero, Jan 17, 2005.
  1. Nero
    Nero
    Jun 24, 2002
    381
    Essex
    +7
    Having problems with my Sky Plus.
    Have recordered programms on the Sky Plus planner but when i go to play them nothing happens just have a frozen picture of the channel i was watching.
    Have done the usual switched off, planner rebuild and last night when had same problem i did i full system reset but the same problem exists.
    Before i phoned SKY i wanted to see what you guys though as they normally just take you through the above.
    Has my hard drive gone or could it be something else?
    Cheers in advance.
  2. Boy Lex
    Boy Lex
    Have this problem time to time on my regular pace sky box. Which channels are affected? I notice it on C4 in particular. I think it's to do with dish alignment (I know mine's a bit off, it's around 50-60% - just haven't got round to installing it properly. Check out my other post!
  3. Nero
    Nero
    Jun 24, 2002
    381
    Essex
    +7
    Appears to be all channels. But ntoice alot more on ITV. My signal says about 70 %
  4. Nero
    Nero
    Jun 24, 2002
    381
    Essex
    +7
    anymore help?
  5. domlof
    domlof
    Dec 2, 2004
    81
    Brentwood
    Had a similar problem a while back. A temp solution I found was to switch to another channel (other than the one which you recorded from, ch4 if its itv say). Then play the recorded program. Worked everytime for me.
    The probloem went away when I replaced the harddrive with a 250G one :)
  6. mps
    mps
    Oct 16, 2001
    1,545
    London
    +54
    Have u tried doing the housekeeping option:
    You can do this by pressing services 401 Select and choose the housekeeping option.
    WARNING - THIS WILL WIPE THE CONTENTS OF THE HARD DISK
    This should fix the problem :beer:
  7. Nero
    Nero
    Jun 24, 2002
    381
    Essex
    +7
    Yeah already done this.
  8. mps
    mps
    Oct 16, 2001
    1,545
    London
    +54
    I guess you have tried doing a system reset.
  9. Nero
    Nero
    Jun 24, 2002
    381
    Essex
    +7
    Yeah first thing i did
