Is my Sky+ blown up?
Discussion in 'Sky Digital TV Forum' started by StooMonster, Sep 1, 2003.
  1. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Sky+ version 2. Only a few months old. Extremely well ventilated.
    Left it unplugged for a week or so, plugged it in, and it worked ... for a hour or so. Then, no display and will not turn on.
    I unplugged it from the mains for an hour or so, plugged it back it and it does the same. Red light, which blinks off for a second after ten seconds, and then constant red again and nothing.
    I can't hear the fan spinning, but can hear the HD spin up. Is it dead?
    StooMonster
  2. mw3cdj
    mw3cdj
    Nov 12, 2002
    399
    West Wales
    I had kind of the same problem, my box turned of and then would not come back on. I just phoned up sky and they sent an engineer around with a new box.
  3. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Apparantly, most $ky units run too hot, and its quite common for them to expire once fired up after having been turned off for any length of time..:(
  4. snakeeater
    snakeeater
    Jul 26, 2003
    mine did the same thing a few days ago. The engineer is coming out today and I assume he is going to replace the box.
    I really hope i dont have to have a replacement box once a month :(
    How to I go about getting a refund for the SKY+ features and all the viewing Ive missed while its sat there like an oversized doorstop?
  5. Aquarium
    Aquarium
    May 20, 2003
    35
    South Shields, Tyne & Wear
    I had a similar problem with my Sky+ V2 box a few months ago after it had been unplugged for a while for decorating.
    I did manage to get the box up and running again :clap: but, unfortunately, cannot fully remember the steps I took (I was in a panic at the time! :rolleyes: ).
    I do remember that (after reading some other posts on this site) I experimented with keeping the power button and/or the back-up button depressed on the box whilst I plugged it back in and, after a few tries, it finally came to life. :D
    Failing all else, get Sky to replace the box (if you're within the warranty period).
    Good luck.
  6. deman77
    deman77
    Aug 20, 2003
    263
    16
    London
    StooMonster, mw3cdj,
    Did you manage to have it sorted? Did you have your HDs changed, and did you have any problems with the warranty because of this?
  7. mw3cdj
    mw3cdj
    Nov 12, 2002
    399
    West Wales
    HI,
    My problem was sorted within 5 days. All i did was to phone SKY and the replaced the box. No problems since.:rolleyes:
  8. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Worlds best ventilated Sky+ v2 box was dead.
    Tried everything with it, powering on/off holding standby button on/off. Tried forcing download. Nothing.
    Rang Sky, give number for Sky+, rang Sky+, first technical person said unplug it (perlease), second person talked me through forced downloading software "always works" she said, after we tried that three or four times they decided to send an engineer.
    Engineer didn't do anything, just unplugged old v2 digibox, and got new v2 out of box and replaced it. He said that he'd heard of problems when they had been unplugged for long periods (like my decorating).
    However, Sky+ digibox now says hardware is v2.1 in the menus; perhaps it always did and I never noticed.
    Lost all hard disc recording, considering we don't watch television "live" this was quite a lot of programmes.
    StooMonster
