Is my RX-V1600 broken??
Discussion in 'AV Receivers & Amplifiers' started by mlc1, Mar 23, 2006.
  1. mlc1
    mlc1
    I picked up my unit last night and spent some time setting it up as 5.1 with the other two amps (zone 2) going to the kitchen. The manual and posts here say I should be able to select any input, tuner, cd ,dvd,..., for zone 2 but only the tuner works. Is this unit bad or what?
    Actually... being a little dis-jointed here... The unit does have a problem in that after ~2 hours it stops listening to both remotes. I have it in the car and later will be returning it for another. So I am hoping someone here can answer my question before I get there because if it doesn't work as stated I may get something else.
    thanks.
