Is my PW6 scsrt terminal board broken?
Discussion in 'Plasma TVs Forum' started by Bigmonty69, Dec 31, 2006.
  1. Bigmonty69
    Bigmonty69
    Jan 7, 2004
    833
    +75
    I have a Panasonic PW6 which is about 3 1/2 years old.
    Just recently I have noticed problems with Scart via Sky (only thing I use on the Scart connection). The picture has started to go blocky (was near perfect before), the Sky menus are a bit fuzzy and when I change Inputs on the plasma via the remote it goes PC, RGB (the one I'm having problems with) and then RGB showing the same Sky picture that I'm having problems with but it's all grey and fuzzy. It never used to be like this as I only used to be able to cycle between PC and RGB then back to PC, instead of the three settings now?
    I have tried different Scart cables and Sky boxes but the same problem occurs. Does anybody know if my theory about the terminal board being knackered is right, is it repairable or can you still by boards for it?
  2. Bigmonty69
    Bigmonty69
    Jan 7, 2004
    833
    +75
    Anyone? I have swapped my terminal board over to another slot but the problem still exists.
