Is my plasma HD compatable?
Discussion in 'Plasma TVs Forum' started by John Langton, Mar 6, 2005.
  1. John Langton
    John Langton
    Hi this is my 1st post and was hoping to get some help. I have a few questions really hoping to find answers
    I own a Fujitsu P50XHA10US
    1. Is this a US model and what is the difference between the P50XHA10US and the P50XHA10EX? I bought it from sevenoaks.
    2. Is my plasma HD compatible?
    3. At the moment I am not getting the most out of my plasma having it connected with the scart. Is it worth buying the new board with component inputs or is it cheaper and better to just use the DVI input? What gives the best quality DVI or component?
    4. If i need the board where is the cheapest to get one from?
    5. Im due to upgrade my DVD player (currently using a PC as one) what is recomended for my plasma?
    Thanks and hope you can help
    John
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
  3. John Langton
    John Langton
    "if it has an HDCP DVi or HDMI input yes (will need to handle 720p at 50Hz and 1080i at 50Hz to be Sky HD compatible"
    That means didly squat to me im afraid Im not as clued up on the whole HDCP or DVi or HDMI as I thought I was. So it needs to be explained a little simpler but thank you for the quick reply
    John
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    if i could get acrobat to read the file i could probably tell you, doesnt look good if my recolection of the 42HHA10EX is correct but the US model may have had DVi but not sure if it would be HDCP.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    OK sorted Arcobat! it has DVi a quick email to Fujitsu (Kash Gill) should confirm either way but off the top of my head there will be a way to make it HD compatible, question is how much £££ will it take...........(hopefully not much)
  6. John Langton
    John Langton
    "there will be a way to make it HD compatible" what will this consist off? Having to take plasma to shop and getting something done on the inside or will it be able to do at home? So what exactly does the plasma need that it hasnt got to enable the HD and is this regarding just watching HD TV (sky digital) as Im thinking if i buy a HD DVD player and hook it up to the DVI input then I will be able to watch HD DVDs or I guess Im ust getting it all wrong and confused!
    John
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    John as far as i can see ther eis no mention of HDCP support or 50Hz support but it can be done....I'll PM you some details...
  8. John Langton
    John Langton
    Thank you very much for your help and still looking for answers to other questions if possibly from people
    John
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    PM explains it all mate see what you think and HD "readiness" and best settings, as well as cabling etc
    unfortunately it is not as simple as just connecting to the DVi input...
  10. John Langton
    John Langton
    Any more for any more?
    John
