Is My Plasma Fu£@ed
Discussion in 'Plasma TVs Forum' started by nokiauk, Sep 15, 2005.
  1. nokiauk
    nokiauk
    Dec 28, 2004
    873
    Edinburgh
    +47
    Turned plasma on tonight for the footie and I have a permenant blue vertical line on the picture, changing channel or turning off & on hasn't removed it.
  2. Peabo
    Peabo
    hehe, is it a Samsung by any chance?
  3. nokiauk
    nokiauk
    Dec 28, 2004
    873
    Edinburgh
    +47
    nah worse than that it's a daewoo
    still prob get swapped for another manufacturer from the store
  4. Peabo
    Peabo
    I think this is a common problem with cheap plasmas. It happened to my Samsung twice. I suggest swapping it for a different make like you said.
