Is my Pioneer PDP-433MXE going to work
Discussion in 'Plasma TVs' started by Darbyweb, Mar 27, 2003.
  1. Darbyweb
    Darbyweb
    Mar 18, 2003
    57
    Bedfordshire
    During to discussion with John Sim, he has pointed out that the Pioneer probably needs the PDA5002 input card ??
    Am i going to get anything without this ?? - if this is the case, whats the point of selling it without ??
    Help please - i'm coming over all hot and bothered at the moment :confused:
    Dean.
  2. philipb
    philipb
    Mar 6, 2002
    1,986
    63
    Swindon
    +132
    Without the 5002 card you get a VGA input and a component (BCA) input, but no composite, s-video or DVI. So yes it'll work fine but you're a bit limited in connectivity. Having said that I rarely use s-video and never use composite, but the DVI is definitely worth it for hooking up to a PC.
    Personally I would recommend you get the card, but it's not a must have by any means. If you can afford it you might want to wait for the new Key Digital card with loads of connectivity and a price of around #1500+:rolleyes:
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,283
    The Borders
    +2,573
    Darbyweb
    The Pioneer PDP-433MXE and PDP-503MXE without the PDA-5002 card will ONLY input a PC type signal on Input 01. VGA and Input 02. 5 x BNC sockets - you cannot input a Video signal (15.6Khz) from one of Johns converters into either of these inputs without the PDA-5002 being present.
    The displays are available without the card for those who are only running PC type signals - lots of Corporate installs for example and also for those who plan to use an external processor that outputs at PC rates/resolutions or the soon to be released third party video cards for fitting in the card slot.
    Best regards
    Joe
