Is My Pio Developing a Fault?
reckless
I've got a pio 435xde and I've noticed something a little strange over the last few weeks.
I've noticed that when I catch GMTV in the morning before I go to work, the sofa, which is normally a dark red, seems to intermittently look as though it's going low resolution colour and all the shading on there appears blue or purple. Put simply the screen looks as though it's displaying lower than the usual amount of colour.
I had thought it was low transmission quality on digital but I'm on hols today and checked it against the analogue signal and that, if anything, is worse. I've also checked BBC and that did the same on reds.
The picture seems fine on all other colours and it doesn't happen all the time.
Has anyone else noticed this problem or is this the beginning of a fault?
Just looking at it now and it's ok. 10 mins ago and it was bad. Any thoughts would be appreciated.
reckless
Just a hopefull bump in case anyone hadn't seen the post today.....sorry to be a nuisance.
