Is my Denon 3802 playing up?
Discussion in 'AV Receivers & Amplifiers' started by Ash007, Jul 18, 2003.
Tags:
  1. Ash007
    Ash007
    Dec 29, 2001
    217
    16
    Rochdale
    I have my Denon3802 setup - Front spkers - Large
    Sub - LFE
    so that (as it says in the manual) my sub should only work when playing the .1 bit of 5.1 Dvds, (stereo should just use the two front speakers)
    But, if I play a Cd in Stereo,there is still bass going down the LFE from the subwoofer output to my subwoofer.
    Why is this happening?
    Does anybody know.
    Ash
  2. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    Don't know your amp but try direct mode that might work.
    Not helping much i'm i.
  3. Ash007
    Ash007
    Dec 29, 2001
    217
    16
    Rochdale
    what is the difference between "direct" and "stereo"?
  4. Hawklord
    Hawklord
    Feb 15, 2003
    3,443
    Aldershot, Hampshire
    +266
    If you don't want the sub to work during cd playback either switch the sub off or adjust your sw to off in the Channel volume menu on the amp for the cd source. Using direct mode uses the players dac's whereas if you use stero mode on the amp the amps dacs are being used.
  5. Ash007
    Ash007
    Dec 29, 2001
    217
    16
    Rochdale
    Its coz i'm setting my amp up with a Rel, which takes its bass for stereo off the right and left front speaker channels, rather than the LFE
  6. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    Direct mode bypasses the processors so no sub out.
  7. Jase
    Jase
    Mar 16, 2001
    9,470
    South Coast
    +894
    Just to clear things up a bit about the DENON. DIRECT mode bypasses any Bass Management and sends full range signals to the front left & right channels regardless of what you have selected in the speaker setup menu (small/large etc).
    DIRECT also has subwoofer output which can be switched OFF if need be.
    DIRECT will also use the amps DAC's when the source input is DIGITAL. These are bypassed with an ANALOGUE signal.
    STEREO mode uses bass management and takes into account the speaker setup that you have selected (small/large etc).
  8. mick23
    mick23
    Mar 20, 2002
    801
    uk
    jase live and learn.
    so if one uses cd player digital conection direct mode (amps dacs are used)
    if using cd players a/log connection direct mode (the cds players dacs are used)
  9. Jase
    Jase
    Mar 16, 2001
    9,470
    South Coast
    +894
    Yes. That's it. :)
  10. Ash007
    Ash007
    Dec 29, 2001
    217
    16
    Rochdale
    There is still output from the subwoofer output whether the Amp is on Direct or Stereo. I have all speakers set to large, and I am using the anaolgueCD inputs.
    This seems inconsistent with the instructions that says there should be no output from sub/LFE/.1 channel from a stereo source when setup this way. (All base to the fronts).
    Also
    when i connect to my Rel with both the LFE and the other connecter concurently (like it says in the instructions) I seem to be getting Mid range as well as bass coming from the subwoofer.
    What is going on?
    I've followed the manual for the 3802 and the REL.
    What could I be doing wrong?
  11. Jase
    Jase
    Mar 16, 2001
    9,470
    South Coast
    +894
    It's because you are using BOTH the High Level and Low Level connections on the REL. Disconnect the High Level (neutrik) and you shouldn't get any signal going to the sub.
    With the High Level connected the sub is receiving a signal from the front left and right channels of the amp (which are set to Large).
    With your REL you can have the best of both worlds if you want i.e all speakers set to Small, all bass to Sub for movies and then for music use the DIRECT mode and you retain full range signals for the front speakers (with or without sub output via low level). You would need to use Mode 2 on the REL (if your model has this Mode switch) as this ignores the sub crossover at low level as the crossover frequency will be set by the amp e.g 80hz.
    If you use the High Level connector as well then just adjust the crossover and volume on the sub to blend with your front speakers e.g 50hz.
