dockerslund
I've got an Intel Pentium 4, 1.5GHz with 512MB ram.
I've been editing my first film in Windows Movie Maker 2.
And...that's the last time I will use this piece of software.
First of all, WMM2 sometimes take a splitsecond of a clip, and add it between two other clips. But it adds it as a part of one of the other clips, so I have to cut a tiny bit off one of the clips.
Another problem. Quite ofter between clips, WMM2 makes this little noise, which I best can describe as little tick. Again I have to go in and remove it, as it's part of one of the clips.
WMM2 has managed to make a couple of other "tick" sounds after I've removed them the first time.
The very last problem...when I add transitions or text animation, the video seems to turn a tiny bit slower.
Is this to do with my computer, or is it the software?
I've decided to go for either Pinnacle Studio 9 or Ulead Video Studio 7.
From what I can read, Ulead VS7 is a lot more stable that Pinnacle Studio 9.
Is that true?
Is that true?
