Is my AVR300 faulty - someone please help
Discussion in 'AV Receivers & Amplifiers' started by Dean_S, Mar 10, 2005.
Tags:
  1. Dean_S
    Dean_S
    Hi there
    I bought my AVR300 in November. It has been running upto now without any problems. It has v3.08 firmware in it.
    Last night, for the first time ever, I tried to use it to switch component video. I think my unit is faulty, here's why:
    If I use the SAT & AV component inputs, everything if fine. However, if I use the DVD input, the 'Pb' or blue channel is missing from the picture.
    It is not the cables or the source; I have eliminated these from the investigation by using the same source and cable and alternating between each of the inputs.
    Could it be a firmware bug? Could someone from Arcam please help or comment. I don't really want to return the unit and wait for weeks, because I won't be able to hear the TV (my display has no speakers). I don't own another TV! I also won't be able to hear CDs!
    Please help,
    Dean
  2. Gavlaw1
    Gavlaw1
    Dean
    You may need to ensure that your DVD player is using the component outputs for component and not RGB. I made this mistake at first and saw a similar problem. In order to set up the DVD to start with, you may need to use a lower definition input in order to see the menus (I'm speaking from experience in using the DV79).
    Gavin
