Is my 725 knackered??
Discussion in 'Blu-ray & DVD Players & Recorders' started by mjn, Aug 13, 2002.
  1. mjn
    mjn
    May 24, 2001
    23,219
    Herts, England
    +11,454
    During playback of discs i get the following problems:-
    :- very loud noise coming from drive itself
    :- breaking up of picture, and producing digital artifacts
    :- getting C13:00 error when putting disc in
    :- DVD will randomly jump from end of disc to beginning of disc.
    I've tried using a dvd cleaner, any other suggestions?
  2. Squirrel God
    Squirrel God
    Very common error with some Sony players.
    Do a search on the Web for it and you'll see what I mean.
    Here's one site to keep you going for now (different model to yours) ;)
    http://www.ben-morris.net/dvd/
    .... but note that there are other fixes and other advice out there which vary from player to player.
    Google Groups are also a good source of info on this: http://groups.google.co.uk/
  3. mjn
    mjn
    May 24, 2001
    23,219
    Herts, England
    +11,454
    oh......had a good look round.....and it seems i have 3 options?
    1) Warm the soldering iron up , and do the old "fuse" fix
    2) recalibrate the lasers
    3) Buy a new player
  4. Geoffc10
    Geoffc10
    go to www.techtronics.com look under problem discs. should find a fix for sony 725, you need to get the laser realigned which you can do by pressing a few buttons on the remote ( the site has the correct sequence) not sure if you will have to do this everytime you use your player though
  5. Mr Merrick
    Mr Merrick
    Mar 29, 2002
    462
    London
    +13
    I had the exact same problem with my 725 last year. I sent it away to be modified to play RCE discs. 3 days after it was returned I began to experience these problems. The manager of the mod company was very helpful and ran me through the bios setup in order to re-align the laser. Unfortunately this didn't work so the laser had to be replaced...luckily (as a goodwill gesture) they replaced it as my coverplan insurance was within 2 days of expiring. Stroke of luck I guess. I sold the 725 in April and have been watching my DVD's on the PC (Ouch!). I finally got a Denon 3800 in July but am having withdrawal symptoms as I don't have Region 1 yet. Bwaaaah! Can anyone help?
