Is my 360 buggered?
rommi
When I turn it on, i get 3 solid lights on the console around the ring of light.
(nothin' on the screen)
Lights
Xo
XX
X = red
The manual talks about 2 lights (video cable) and 4 lights being its internally broken.
This only happened when one of my kids plugged the ethernet connection in.
If it is broken, does anyone know the MS service telephone number, as the manual didn't seem to list that either.
lightbulb
here you go:
Phone
Assistance by phone seven days a week:
0800 587 1102
or +44 20 7365 9792 from a mobile phone
Hearing Impaired (TTY device):
0800 587 1103
Hours of operation:
Monday-Friday: 09:00-22:00
Saturday: 09:00-20:00
Sunday: 09:00-17:00
taken from http://www.xbox.com/en-GB/support/contact/
[edit] just realised this probably doesnt apply as you are experiencing 3 solid lights rather than flashing lights. I'll leave it here for anyone else that finds this thread through a search :)
Also give the following a go, from llamma.com
The specific type of hardware failure can be determined by a "hidden" error code
* Turn the xbox 360 on, and wait till the 3 red lights are flashing.
* Press and hold the sync up button (the small white one), while holding that button press the eject button.
* The LEDs will now blink the first number in the code (as described below).
* Release the eject button and press it again.
* The LEDs will now blink the second number of the code.
* The LEDs will now blink the third number of the code.
* The LEDs will now blink the forth number of the code.
* The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
* All four lights flashing - 0
* One light flashing - 1
* Two Lights flashing - 2
* Three lights flashing - 3
0001 power supply problem
0002 power supply problem
0010 over heating
0011 over heating
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0022 GPU Error / GPU Overheating
0102 unknown error - littereally means the console does not know what is wrong. possibly a short or cold solder joint somewhere (2 reports of people repairing this, one was removing moisture build up inside the console, the other used a hot-air rework to reflow the BGA Ram chips)
0110 (Not yet known)
1022 (Not yet known)
