Is my 32PD50 compatible with progressive scan from Sony HX710 ?
Discussion in 'General TV Discussions Forum' started by Ysl, May 5, 2005.
  1. Ysl
    Ysl
    Nov 24, 2004
    38
    Here's is what they say in the Sony user manual :
    Consumers should note that not all high definition
    television sets are fully compatible with this product and
    may cause artifacts to be displayed in the picture In the
    case of 525/625 progressive scan pitture problems, it is
    recommended that the user switch the connection to the
    standard definition output, If there are questions
    regarding our TV set compatibility with this model 525p/
    625p DVD recorder, please contact our customer service
    centre
    Thanks to the specialists you are...
  2. Ysl
    Ysl
    Nov 24, 2004
    38
    Hello, now I tried and can answer my own question...
    Yes, the hx710 is fully compatible PS, tried PAL and NTSC DVD, no problems..
    I must add that the 32PD50 delivered a HIGHLY superior quality image from anything inputed in the HX710 (Sat/Pioneer DVR720...) and outputed in progressive scan.
    Also, DVD movies are FAR MORE superior quality in PS mode than Y/C or RGB
    I just rediscovered my tv set and was stuck in front of it as the picture quality was soo good, no more artifacts, pixelisation, strange effect on faces...!!!
    Will never use other input than YUV now...
    But the Sony did not totally convinced me so I will try next week the new Pioneer DVR 530
  3. Meeko
    Meeko
    Mar 30, 2005
    182
    +13
    I agree that YUV is the way to go, but with my PD50 and DVDS97 in PS mode the picture is worse than standard interlaced. Weird huh?
  4. erg
    erg
    I just bought a Panny 36PL35F (same set as 36PL32 in England). And I loved it. Some people here in this forum indicated the P.S. is worse than any other connection for some DVD players while better for others.
    So do any other PL32 (PL35) or PD50 owners suffer from the same thing? How on earth I can know in advance that a DVD player will be a good fit for PL35?
  5. Ysl
    Ysl
    Nov 24, 2004
    38
    I think PS is as good as the circuitry in your DVD player/recorder...
    Some DVD player deliver very poor PS picture....
  6. erg
    erg
    I agree, since the TV is capable of displaying faultless progressive pictures with some DVD players then with a lower quality display it is the DVD to blame.
