Is IXOS 1081 Subwoofer cable OK?
Discussion in 'Subwoofers' started by Jon Weaver, Jan 6, 2002.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,160
    Born in Bristol but now in Newport, (for my sins)
    +717
    I wouldn't normally buy things like cables from Dixons, but I happened to be in there yesterday and saw that they sell the IXOS range.
    They had a Subwoofer cable (model 1081) for £19.99.. This didn't seem cheap, considering that it is only mono, but I had a credit note and thought that it would be a good way of spending it.
    WHen I got home, I realised that it was part of IXOSs 'bronze' range, which in my mind equates to 'budget'
    Has anyone tried this cable? Is it a worthwhile upgrade over a bog-standard cable?
    Any info appreciated.
    Jon
  2. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,160
    +717
    I found the same cable at 'homecinemaheaven' for £9.95, so it was hardly value for money.
    I also found an IXOS cable called 1141, which is apparantly, much higher quality.
    Homecinemaheaven want £25 for the better one, which is only £5 more than the £20 I have already payed at Dixons.
    But for £10, I might as well get the 1081 cable and take the one back to Dixons.
    I don't know what its like, but for £10, you can't really go wrong!
  3. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    Portsmouth / Middle East
    +77
    Hi again Jon,
    Your not gonna really spot the difference so I'd go with the 1081 it really does the job well. Unless you've got a real jumble of wires behind your av gear and feel you really need to isolate everything well (and I hope its not like that) stick with the 1081 but not at 20 smackeroonies though mate!
