Is it worth waiting for cheaper hi-def DLP?
Discussion in 'Projectors, Screens & Video Processors' started by Lobo, Jan 19, 2005.
  1. Lobo
    Lobo
    Feb 4, 2004
    219
    +3
    Im looking to buy a DLP projector soon. I am initially swaying towards the Screenplay 5700 at £2200 as I have seen the picture from this projector and I loved it. However, I will be hooking it up to an HTPC and therefore thought it would be beneficial to have a hi-def projector (possibly using the HD2+ chip).
    The problem is these projectors are generally in the region of £5000, a bit out my price range. Is it likely that good quality hi-def DLP projectors will fall below £3000 in the near future or should I just go for the 5700?
  2. stuthemong
    stuthemong
    Dec 31, 2002
    432
    +6
    you could look at the 7200 - extra res does help with HTPC
    though a recent purchaer of a 7200 (peter123) was annoyed by its noise.
    Stu
    Prices will always drop, if you can wait 12 months, i guess you may be OK.
  3. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,015
