Is it worth using High Quality SCART cables if you use a SCART switch?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jon Weaver, Apr 11, 2001.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,160
    Born in Bristol but now in Newport, (for my sins)
    +717
    As my TV only accepts 1 x RGB input, and I have 2 devices that I want RGB from (Dreamcast & DVD) I use a SCART switch.
    All my SCART cables are 'normal' quality, and I wonder if its time to get some better quality ones.
    The problem is that for me to get a quality cable from the DVD to the TV, will require 2 cables (one from DVD to Switch, one from Switch to TV).. Whilst this isn't a problem (other than the cost), it seems to defeat the object, as the switch is hardly High-Quality.
    I guess that any benifit gained by the quality cables, will be lost in the switch.
    Is it still worth upgrading the cables?
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,247
    71
    +43
    Unless you can find a high quality switching unit from somewhere, but doubtful.
    The thing about high quality leads into TV's is that the scart socket it reaches in a TV is 'only' plastic with crappy conductors inside anyway. So really the lead provides a good quality signal for as long as poss. to the socket, then it is treated 'badly' as it were from there on in. Unlike high quality source units in HiFi/AV which provide good signal incl. leads all the way to the speakers!!!!!!
    Just something to chew over.
    Personally, If you absolutely have to have a switcher, I wouldn't go mad on the overall lead quality/cost.
