Hallsy
Established Member
Right, had pretty much decided that I would get a cambridge audio M1+, or E-Pilot SRC-9200 (both the same) for around £30 from ebay. After hunting around and looking at other remotes you seem to geta bit pulled in and before you know it you're considering spending loads more on a really posh one!!
Being a little more restrained I have noticed that you can get Marantz RC3200 or even Pronto 890 for around £60 on ebay sometimes.
The question is, is it really worth doubling the price to get something like this?
I was after one to replace remotes for 5 bits of kit (will soon be expanding to 7), as well as helping the other half out!! I would use the macro facility for turning things o together, with source switching, etc.
I like the idea of the more fancy remotes but not sure if I'd really need them, whe possibly the M1+ style remotes would be adequate??
What do you guys reckon?
